Transmission warning light stays on
115,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JEEPGRAND2004
Transmission warning light stays on. Transmission works fine and fluid level is okay. Recently came down a long steep grade in second gear which in the past has triggered the light, but it would eventually go off. This time it has stayed on.
Aug 2, 2019 at 7:42 AM
We need to find out what codes are in the control module. If you don't have a scan tool, most parts stores will pull them for you free of charge. Unfortunately this could be a number of things so we need the codes to limit it down. Thanks
Aug 2, 2019 at 9:35 AM
