Transmission trouble
155,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
JAMES ALLEN TAYLOR
The transmission slips. It has the correct transmission fluid and it is on the full mark. I have changed out the fluid to new fluid. I use the red bottle that says Honda's only transmission fluid and it still slips. Right now it is stuck in first and second gear and I have to use the gear shift. I can not drive it in d4 and drive it. I have to put it in first then d3 or d4 just to get it in second gear. It will not go into third or fourth gear. What should I do?
Aug 12, 2018 at 8:27 PM
  • 55,746 POSTS
This is a common problem when the turbine sensor goes out. Here is a video that shows the repair being done:
https://youtu.be/KRTJYOXuON8
Cheers, Ken
Aug 14, 2018 at 4:43 AM
