Transmission temperature sensor
1999 DODGE DURANGO
150,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
JAYHAWK303
Intermittently my transmission temperature light will come on followed by my OD off-white as well the problem comes and goes as fast as one another. transmission has been flushed is clean and is not running hot it also does not throw codes bypass the check valve that is not the problem either. gov pressure sensor replaced two years ago. How can I either bypass the ODlimp mode, or other repair? thoughts?
Aug 16, 2016 at 3:26 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
It sounds like the transmission is going out and needs a rebuild.
Best, Ken
Aug 19, 2016 at 9:12 PM
