Transmission swap
90,000 MILES • V8 • 2WD • AUTOMATIC
RJSCARCE
I have a 2007 F150 with the 5.4 liter and my transmission is a 4R75E. I found another 4R75E but it's out of a 2008 Crown Victoria. My question is, will it be a direct replacement? I know the torque converter will have to be from a 5.4 engine but not sure of any other issues doing a swap like this. Thanks in advance.
Feb 19, 2021 at 3:52 AM
Yes, the components inside the unit and case are exactly the same so you will not have any issues.
Here is a video that does a pretty good job explaining the differences but again, if you are sticking with the 75E then you are just fine:
https://www.youtube.com/watch?v=hU4EcL7fRPM
Let us know if you have other questions or need more info. Thanks
Feb 20, 2021 at 7:14 AM
RJSCARCE
I was also told then when i asked someone else the same question . Measure the tailshafts, one may be shorter than the other. To swap tailshafts the whole transmission has to come apart. The shift lever is in different locations, that's a bit easier to swap. Is this something I need to check on? And just to make sure the transmission code on the sticker in the driver side door jamb is Q. That would mean I have a 4R75E correct?
Feb 20, 2021 at 8:16 AM
RJSCARCE
I'm trying to find out what years of the 4R75E 2wd transmission will be a direct replacement/plug and play on my truck listed above. And does it matter what Ford vehicle the 4R75E comes out of. Please help. Thanks in advance.
Feb 21, 2021 at 4:31 AM (Merged)
STEVE W.
  • 15,389 POSTS
Looking at the interchange it needs to come out of a 2007 or early 2008 F-150 or the Lincoln Mark LT. The E-150/250 transmission for 2005-2008 will work as well if it has the same engine and the PKF-FJ,GJ tag. No other years have the correct internals.
