The transmission shifts fine when first pulling out from a stop. After the torque converter locks up, it shifts into first gear and will not shift unless car is restarted. Replaced the valve body in original transmission, still had the same problem. Replaced the transmission with junkyard part, same problem. Getting a little frustrated with this thing. Also, checked the wiring and fuses.
Nov 9, 2017 at 5:56 AM
