Transmission speed sensor
1999 DODGE DURANGO
117,000 MILES • 5.9L • V8 • RWD • AUTOMATIC
EDWIN REYNOLDS
Car gets to 2000 rpm and stays too long, have to accelerate past it. is it a speed sensor or what?
Sep 29, 2017 at 6:45 PM
STEVE W.
  • 15,351 POSTS
Are you saying that it stays in gear and will not shift?
Or that you get to 2000 rpm and the engine loses power?
Is the check engine light on? Does it do this all the time or only when cold or hot?
Please help us help you.
Sep 30, 2017 at 6:30 AM
EDWIN REYNOLDS
Gets to second gear at about 2000 stays there too long. engine has plenty of power. usually have to accelerate to make gear change. no check engine light. does it all the time hot or cold.
Sep 30, 2017 at 6:49 AM
STEVE W.
  • 15,351 POSTS
Was hoping you would say it only does it when cold. But it sounds like the solenoid pack is starting to go. The problem is that usually this behavior also indicates that the front band is worn/slipping and the transmission needs to come apart.
I would take it to a transmission shop and have them take a look. It could be just the pressure sensors and solenoid. They are a common issue on that transmission.
Sep 30, 2017 at 8:05 AM
