Transmission slipping
124,000 MILES • 3.6L • V6 • FWD • AUTOMATIC
DAVIDXX12345
Transmission revved up to 4000, speed ten mph only. Limped home; No check engine light or codes on hand scanner. Restarted half hour later runs okay.
Need ideas of what the issue might be.
May 31, 2017 at 1:35 AM
  • 55,770 POSTS
This sounds like an internal transmission seal is failing when hot which is a sign of wear. If there are no codes then typically it is a mechanical failure. The transmission may need to be rebuilt.
Please let us know what happens, we are interested too see what it is.
Cheers, Ken
May 31, 2017 at 6:18 AM
