Transmission pan bolt broke off inside
2010 CHEVROLET COBALT
100,000 MILES
SETH7383873
  • 15 POSTS
I went to do a transmission filter change and while taking the bolts out one of them stripped and snapped off inside. I’ve tried drilling a whole into to try and get a bolt extractor to go in but it will not budge. I’ve also used penetration oil on it but cannot get it out.What else could I do to seal the transmission pan without that bolt?
Apr 23, 2020 at 9:26 AM
  • 110,241 POSTS
You could use a form a gasket to help seal that area, but it may not last. Have you considered drilling the entire broken bolt out and then re-threading the housing and using a different bolt? That is what I would honestly be doing. If drill enough of the bolt out, it should come out. If that doesn't happen (as you mentioned) get a drill bit the same size and the bolt and drill it entirely out and tap new threads into the housing and then replace the bolt with the new size.
Let me know if I can help.
Apr 23, 2020 at 9:41 AM
