transmission leak and complete failure to shift
150,000 MILES
TROYE77
I've owned my car for a year and never had any transmission fluid loss, slippage, or other problems. I stopped my car to pump gas, got back in and I have no gears whatsoever. I check fluid and it is completely empty. Refill transmission fluid and still nothing. It's like it's not even connected when I put in gear.
May 30, 2013 at 6:05 AM
  • 31,937 POSTS
Problem may be a failed transmission pump or a valve body problem, it may be stuck in park or neutral (internally) this will have to be checked by a transmission specialist, you will need specialist test equipment to find this problem.
May 30, 2013 at 7:23 AM
