transmission jerk or hard push after 45mp and up.(only high speed.
200,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
SAINT69
transmission change perfect but if you go more that 44 ,45 miles it get a hard push and the more you speed more you get another extra hard push. Can this be a transmission speed sensor mess up. need your help to determine where this problem coming from . Motor and transmission were change about few month ago .recently bought this car.
Apr 29, 2014 at 12:14 PM
  • 110,248 POSTS
Is the speedometer working properly? When you feel the push, is the transmission changing gears?
Apr 29, 2014 at 10:13 PM
SAINT69
Yes speedometer stay the same normal ..at Low speed is find just everything happens after speed of 45 and up weird...I was thinking can it be transmission speed sensor.?
Apr 29, 2014 at 10:18 PM
  • 110,248 POSTS
Usually, a VSS will cause a problem with both the trans shifting pattern as well as the speedometer.
Apr 30, 2014 at 1:30 AM
