I get a hard shift after passing 10 MPH
1997 CHEVROLET 1500
2,135,200 MILES • 5.0L • V8 • 2WD • AUTOMATIC
CWINE84
  • 8 POSTS
Hey, when I start my truck and start driving it runs and shifts fine the problem only occur after riding for a while. If I come to a stoplight and stop and then accelerate I get a hard shift after passing 10 MPH. I replaced the center bearing thinking that could be the reason but it wasn't. I thought about flushing and changing the transmission fluid and filter but I got mixed reviews saying don't change the fluid it would make it worst. I also heard the rear end can cause that issue too. Looking forward to your help
Jan 4, 2021 at 8:10 AM
Good evening,
The hard shifting is a transmission issue only.
I would change the fluid and filter but do not flush.
If that does not work, you may have a bad seal in one of the clutch drums.
Jan 4, 2021 at 8:31 AM
Did you respond? I got an email but nothing came through.
Jan 4, 2021 at 7:02 PM
