Transmission issue?
2015 DODGE GRAND CARAVAN
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
I know these have common transmission issues. I changed all mounts and the transmission fluid and has gotten better. The only issue is when I am about to come to a full stop i get a bit of a downshift and RPMs show it, something that has to do with torque convertor i think not locking or unlocking. Will something like insta shudder fix take care of such issue?
Sep 19, 2022 at 10:47 AM
  • 110,244 POSTS
You are correct. The torque converter is what allows the vehicle to be stopped and remain in gear. To a degree, you may notice the downshift, but it shouldn't be abrupt. Also, you could try an additive designed to improve shifting, but it may not help.
What really should be done is this. The can-bus should be scanned to see if there are any diagnostic trouble codes stored. CAN stands for controller area network. Basically, all the different computers/modules are tied together via a few wires, and they communicate with each other. This type of scan will identify codes regardless of the module storing them.
Here is a link showing how it's done:
Let me know if you have already tried having that done. Also, an additive won't hurt. It may be a good idea to try. Just make sure to get a good product.,
Sep 20, 2022 at 12:19 PM
