Transmission interchange/swap?
2001 FORD EXPLORER
20,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
MELANIE MOMENT
Is a 2001 ford Explorer XLT transmission interchangeable with any other vehicle?
May 6, 2023 at 12:49 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
The automatic transmission used in the 2001 Explorer XLT is the 5R55E, which was also used in several other Ford vehicles, including the Ford Ranger, Mercury Mountaineer, and Mazda B-Series pickups. However, it is important to note that even within these vehicles, there may be differences in the transmission depending on the year, engine, and other factors. I would check the electrical connector to make sure they are the same and the output shaft.
May 6, 2023 at 12:54 PM
