transmission does not shift into reverse or neutral?
86,000 MILES • 5.0L • V8 • AUTOMATIC
TRSRHDDN
the transmission doesn't go into reverse or neutral, only drive. When shift into reverse or neutral it goes into drive. I adjusted the shifter and still the same problem.
Aug 7, 2022 at 1:16 AM
  • 55,732 POSTS
This is a valve body problem one of the valves is stuck. Here is how to remove the valve body so you can get a rebuilt one.
You will need to drop the pan and drain the fluid and refill. This guide should help walk you through the job:
REMOVAL
1. Raise and support vehicle, drain transmission fluid, then remove transmission pan, gasket, and filter.
2. Remove detent spring attaching bolt, then the spring.
3. Remove valve body to case attaching bolts, then the valve body.
INSTALLATION
1. Reverse procedure to install.
2. Use suitable guide pins to align valve body to case.
Aug 8, 2022 at 2:58 AM
