Transmission fluid compatibility
123,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JESSIE WORTHINGTON
Is dex/merc compatible with atf +4?
Jun 11, 2019 at 1:16 AM
Hi Jessie,
The oil manufacturer says they are compatible but Chrysler says nothing but ATF +4. I have found that when you mix them or replace with dex/merc it shifts firmer. I don't really like that so I would stick with what the OEM recommends. I understand it is a little more expensive but they designed it to use that fluid not any other.
If it were me, I would stick with what they recommend.
Let me know if you have any other questions. Thanks
Apr 21, 2021 at 8:31 AM
