Transmission flex
102,000 MILES • 1.9L • 4 CYL • FWD • AUTOMATIC
CHRIS ALWARDT
My car seems to have a problem when first started. I put in gear and get a clunk sound. Then as I drive it has problem shifting from gear to gear. I used to drive a stick, so I know when to lift my foot for shift. Then sometimes my engine tachometer would shoot up. Now, after say five minutes, I can turn engine off with no shift or racing issues. Could this be a ECM/PCM issue or just simple replace transmission fluid and filter?
May 11, 2017 at 10:20 AM
SATURNTECH9
  • 30,869 POSTS
So when you say you get a clunk sound when putting it in gear is this reverse or drive?Are we talking about a delay bang into reverse?
May 12, 2017 at 11:18 AM
CHRIS ALWARDT
Sorry for taking so long getting back.
This clunk I notice when I put it in reverse.
If I let the car sit for 5-10 in idle, I can start moving forward with no issues. I can go somewhere. Park the car. Then in couple hours go out with no issues. I check the fluid and it doesn't smell burnt or any Oder out of the normal. Thanks
Jun 1, 2017 at 4:59 AM
SATURNTECH9
  • 30,869 POSTS
So is there a delay bang into reverse?Also have you checked for codes yet in the computer?
Jun 1, 2017 at 6:05 AM
