transmission has a pause engage when shifted into drive?
232,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TOMJJONAS
  • 10 POSTS
when i put my transmission into drive there is a very short pause before it goes into gear. what's my problem its only drive, not reverse?
Jul 16, 2023 at 4:34 AM
  • 110,248 POSTS
What you described can be caused by a few things. First, low or dirty transmission fluid. Also, there could be a hydraulic pressure issue. However, based on the mileage, you could simply have a seal that is going bad and allowing trans fluid to bypass it for a bit before it reacts.
So, have you checked the transmission fluid level and condition? Also, have you checked to see if there are diagnostic trouble codes stored? If you haven't, here is a link that explains how to do it on a GM OBD1 system. You don't need a scan tool. All you need is a short jumper wire or even a paper clip.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Try that and let me know what is found. Also, let me know the condition of the fluid.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Jul 16, 2023 at 2:22 PM
