Transmission control module pin data
1994 ISUZU BIGHORN
200,000 MILES • 3.1L • 4 CYL • TURBO • 4WD • AUTOMATIC
ERICKYU610
my isuzu Trooper wont shift properly to 3 and 4, but 1 and 2 are okay .when i'm driving it need to reach 60 kph before it will shift to third gear and after that fourth gear will not shifted until third gear only and the indicator light on and blinking ATF oil temperature is on. so now i didn't get the code because there is no DLC. can you please give me data pin to scan the problem of my car?
Feb 8, 2020 at 7:47 AM
  • 110,244 POSTS
This vehicle isn't offered in the US, but I will try to help. If the indicator light is coming on and flashing, there should be codes. Take a look through this link. It explains how to retrieve OBD1 codes from vehicles made before 1995. Try this and let me know what you find.
https://www.2carpros.com/articles/odb1-isuzu-1985-1994-cars-and-trucks-code-retrieval-procedure-and-definition
Let me know what you find.
Feb 8, 2020 at 11:14 AM
