Transmission codes P0700, P0732, P0733, P0736, P0601, P0846, P0841
3.8L • V6 • FWD • AUTOMATIC
TRACEY7330
Sometimes it will go right into gear other times Van will move when revved up and jump into gear, then will go in "limp" mode. These are the codes it is sending out. P0700, P0732, P0733, P0736, P0601, P0846, P0841
My question is...Can I fix this problem by replacing the TCM? What other parts might I need? Please help.
Feb 25, 2015 at 1:26 AM
CARADIODOC
  • 34,413 POSTS
The Transmission Computer is detecting problems and reporting them by setting the diagnostic fault codes. You don't replace the computer for doing its job. The first thing is to visit a transmission specialty shop. They will have seen this before. You didn't list the mileage so I can't make any generalization other than to suggest that with multiple gear ratio errors, you could have slippage taking place in one clutch pack that is engaged with each of the reported gears, or this could be as simple as one of the speed sensors reporting an incorrect speed.
The specialist will erase the codes, then see which one(s) come back on a short test drive. They can also look at the "clutch volume index" (CVI) on their scanner. Those are four numbers corresponding to the volume of fluid it takes to apply each clutch pack. With excessive wear to the fiber plates, it will take more and more fluid to apply that clutch, until the point is reached when the computer can't update any more, and that slippage occurs and is detected. That will send it into limp mode.
Feb 25, 2015 at 1:40 AM
