Transmission, brakes, or both
2009 NISSAN VERSA
130,000 MILES • 2WD • AUTOMATIC
DONNIE MARTIN
Had transmission replaced, engine is still running rough when changing gears, specifically reverse. Changed engine torque mounts and noticed small improvement.
Tried to run the vehicle to 'push through' the noise and vibration, and vehicle seems to work normally after getting up to speed, but issue manifests when idling, accelerating from zero to twenty mph, or braking.
Oct 23, 2017 at 1:08 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
So it the engine running rough makes a noise or both? can you shoot a quick video and upload it here so I can see what is going on?
Cheers, Ken
Oct 23, 2017 at 3:27 PM
