When accelerating there is a humming noise
182,472 MILES
TRUCK REPAIR
I am having a humming noise when I accelerate on the highway or even accelerate at regular speed as well. I have changed all the bearings wheel bearings inner and outer on the rear end on the on the front as well. So that is what is making me wonder if there is a torque converter problem making a winding noise as you accelerate at any speed? Transmission or rear end?
Dec 11, 2018 at 10:35 AM
  • 110,248 POSTS
There are carrier bearings in the differential as well as a pinion bearing. Were they replaced? Is there any change in the sound when turning while accelerating? Is this two or four wheel drive? Automatic or manual transmission?
Dec 11, 2018 at 12:10 PM
TRUCK REPAIR
Two wheel drive and the sound seems to decrease when driving like right hand curve like! Automatic transmission.
Dec 11, 2018 at 12:22 PM
  • 110,248 POSTS
If the sound is decreasing when turning right, Recheck the right front wheel bearings. Make sure they are properly adjusted and fully greased. When turning right, you remove some of the weight off the right side of the truck. Since the noise decreases, that tells me it's coming from one of the bearings on the right side.
Did you replace both the bearings and race?
Dec 12, 2018 at 10:08 AM
