Transmission and acceleration
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOEY MAHARAJ
  • 12 POSTS
Good day, mechanics, cs3 Lancer,4g15 sohc and CVT transmission. vehicle had 4g18 engine and changed it to 4g15 ,did not change harness. check light came on. driving at for example 2,000 rpm's as I let go of the accelerator the vehicle would hold back at the same speed and if I keep accelerating I only reach about 80 km and would not go further. although I'm mashing the accelerator. I stopped and take of the negative terminal of the battery, wait 10 seconds and put it back on. No problems so far after I drove it. what is the cause for this? because I recently serviced the throttle body and air intake manifold.
Jan 31, 2020 at 3:23 AM
  • 110,248 POSTS
Have you checked for diagnostic trouble codes? When you changed the engine and reused the wiring harness, were there differences? If you haven't checked for codes, I would recommend it. Here is a quick video showing how it is done:
https://youtu.be/YV3TRZwer8k
I realize not everyone owns a scanner. However, most parts stores will do it for free, so try this and let me know the results.
Jan 31, 2020 at 9:55 AM
JOEY MAHARAJ
  • 12 POSTS
No, I don't have a scanner and parts stores don't do that here. I'm from Trinidad,so any knowledgeable answer would be helpful. I was thinking about the spark plugs, last I changed them was in August 2018.
Feb 1, 2020 at 5:50 AM
  • 55,604 POSTS
To be sure lets do a CAN scan which is the future of automotive repair you can get a CAN scanner from Amazon for about $50.00.
Feb 1, 2020 at 5:51 AM
JOEY MAHARAJ
  • 12 POSTS
Okay then,I will take in consideration of buying a scanner,but since I reset the computer. I haven't have a problem,running as normal as it should.
Feb 2, 2020 at 2:32 AM
  • 110,248 POSTS
If it's running good and the light hasn't come back on, it may be fine. However, I agree with Ken. Let us know if there is anything other we can help with.
Feb 2, 2020 at 10:51 AM
JOEY MAHARAJ
  • 12 POSTS
Okay cool, thanks.
Feb 3, 2020 at 7:40 PM
  • 55,604 POSTS
Here is a video to show you how:
https://youtu.be/InIlnsjOVFA
It sounds like the car is going into limp mode. here is a guide:
https://www.2carpros.com/articles/reduced-power-limp-mode
Feb 4, 2020 at 2:55 AM
JOEY MAHARAJ
  • 12 POSTS
My transmission may need a servicing then,as it has an oil filter inside.last I serviced it was about 4 years ago.
Feb 22, 2020 at 7:49 AM
  • 110,248 POSTS
Has the problem returned? If it has, by any chance, were you able to get your hands on a scanner?
Feb 22, 2020 at 9:26 AM
JOEY MAHARAJ
  • 12 POSTS
No the problem hasn't returned. no not yet.
Mar 16, 2020 at 11:48 PM
