Transmission light on and will not over 2,000 RPM's
125,000 MILES • 1.2L • 2WD • AUTOMATIC
BILLY CLARK
The automatic transmission light is on and when driving it can't go over 2,000 rpm or it chugs. so I think it's in limp mode.
Aug 8, 2019 at 6:36 AM
  • 110,248 POSTS
Welcome to 2CarPros.
That is very possible. In this case, you need to have a scanner to retrieve the diagnostic trouble codes which should point us in the direction of the problem. Here is a quick video that shows how one is used:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but most parts stores will do it for free or lend/rent a scanner to you. My only concern is if a parts store will have a scanner that can read more than just engine codes. However, we need a starting point. If you could, have that done and let me know the results.
Aug 9, 2019 at 1:55 PM
