Transmission
160,000 MILES • AUTOMATIC
JENNIFER MARIE KLIMSON-MUNOZ
I was at my daughter's school today and was in park. I put my car into drive and it did a high rev engine and jump and then it would not move at all. It will now only move normally in reverse and it can move in first gear at only about fifteen miles an hour. I have not had any issues since owning the car with it slipping in gears or feeling it drive sluggish from one gear to the next. What could have happened.
Jennifer
Apr 12, 2017 at 9:55 AM
  • 55,711 POSTS
Hello Jennifer,
It sounds like the transmission fluid is low please check the level with the engine running. Here is a guide to help you
If the fluid level is okay connect a scanner to it and check for codes this will guide us in the right direction here is a guide for that as well.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 14, 2017 at 5:03 AM
