Transmission
2007 LEXUS IS 250
1,109,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
ABBERS
Car changes to fifth and sixth gears only after resetting computer. It runs for a couple miles and then will only change up to fourth until computer is reset again. In sports mode it indicates that it is in fifth gear but revs do not drop.
Dec 4, 2017 at 5:01 AM
  • 31,937 POSTS
sounds as if there is a problem with a shift solenoid, a scan will show up any codes, and not all codes will set a check light, a live data read on a quality scanner will also show what the transmission electrical's are doing re shift solenoids and lock up clutches.
Dec 4, 2017 at 10:18 AM
