Transmission
150,000 MILES
ACCORDGUY10
A few days ago my car wouldn't engage into reverse, i tried replacing the transmission fluid but that didn't help. I've heard it might be my synchro but i'm not sure. what do you recommend I do? I'm stuck parking in a easy pull out spot and its a pain. what should I do?
May 30, 2013 at 7:53 AM
KHLOW2008
  • 41,812 POSTS
Check for trouble codes. There is a possibuility this could be an electrical or solenoid fault but it could also be a transmission internal fault and would require further testings. You would need a transmission specialist to check through.
Jun 1, 2013 at 5:38 PM
