transmission
1994 HONDA PASSPORT
318,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
TOMMYPICKLETT
my transmission starts to slip gears only when I go over 25mph. other wise it shifts into all gears fine upon the start. it is strong in drive,reverse,2nd ,low. Only when I get to 25mph it begins to rev up an slip outta gear.
Feb 19, 2016 at 5:14 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
with that many miles the transmission is probably worn out, Check the fluid level and please get back to us with what you find.
Feb 23, 2016 at 3:56 PM
