Transmission swap
90,000 MILES • 2.0L • AUTOMATIC
JUSTIN MEEK
Is it possible to use a transmission on an older vehicle on a newer one.
Aug 11, 2018 at 3:29 PM
HARRY P
  • 2,292 POSTS
There is some interchangeability between the years, but not much. If it is the same make and model, and has the same engine, and it is from the same generation of the model, then it will probably fit. To be able to give you a more definite answer, I would need the year, make, model, and engine size of each car. Hope this helps.
Aug 11, 2018 at 9:49 PM
