Transmission has a delay and clunk when putting into drive
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
WOODCOCK45
Delay and clunk when put in gear, drive only. Other than that, everything is fine.
Jul 6, 2018 at 7:42 AM
  • 110,248 POSTS
First, make sure the transmission fluid is clean and full. If it is dirty, you should consider servicing it. Here are general directions for doing so:
If the fluid is clean and full or has recently been serviced, check transmission mounts, engine mounts, and axle joints. Here is a link which reviews symptoms of a bad CV joint on the axle. You will see it refers to a clicking, so see if that is happening.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Start with these things and let me know what you find.
Jul 7, 2018 at 1:54 PM
