Transmission
180,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PRINCEMONTIE
Park doesn't work. Also when you put it in reverse it makes a grinding noise, almost like a loose chain on a sprocket, and doesn't move. It does go forward and shifts through all gears, but it does grind a little. I thought it was the transfer case,but I changed that and it didn't help. Thanks.
Dec 23, 2015 at 2:30 AM
you have an internal failure in the trans. if you drop the trans pan, my guess is you will see a lot of material from a bad gear
Dec 23, 2015 at 3:10 AM
PRINCEMONTIE
It is an automatic. Does that matter
Dec 23, 2015 at 3:24 AM
no, I assumed it was
Dec 23, 2015 at 3:26 AM
PRINCEMONTIE
Thanks. Have a Merry Christmas.
Dec 23, 2015 at 3:41 AM
thank you same to you and yours
Dec 23, 2015 at 3:45 AM
