transmission
2002 CHEVROLET TRAILBLAZER
152,000 MILES • 4.2L • 4WD • AUTOMATIC
CASEYD
I have changed the transmission on my vehicle because I was told that is what is wrong. I get it put back together and it is still doing the same thing. Few weeks ago I pull out at a light it shifts into first an then it stopped going it seems like it is stuck in neutral even though I am in any of my gears two wheel drive or four wheel drive not sure what else could be causing the problem.
Jul 11, 2016 at 6:48 AM
HMAC300
  • 48,601 POSTS
scan for codes may be a wiring issue or tcm problem.
Jul 11, 2016 at 8:26 AM
CASEYD
No codes
Jul 12, 2016 at 8:21 AM
  • 31,937 POSTS
What transmission are you running? oil lever ok? correct oil?
Jul 12, 2016 at 8:19 PM
