Transaxle
1997 CHEVROLET CAVALIER
175,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JACKMAXX123
New front end and all new motor mounts, and new TCC. wondering why it clunks when shifting from park to reverse and the motor moves?
Dec 19, 2017 at 12:24 AM
CARADIODOC
  • 34,367 POSTS
Most likely an engine mount was overlooked. GM engines commonly use a "dog bone" mount between the front top of the engine to the core support, just to the passenger side of the radiator. That is what keeps the engine from rocking. If that was not on your engine, the next most common location is underneath and to the rear of the engine. The link would go from the engine to the cross member.
When that link is missing or disconnected, when you shift to "park", and open the hood, you will see the engine rock back and forth excessively when you push the car forward or backward.
Dec 19, 2017 at 6:22 AM
JACKMAXX123
Thats new too, i was wondering if it has somethin to do with the tranaxle like the torque converter or torque converter clutch or a solenoid or somethin.
Dec 20, 2017 at 11:12 AM
CARADIODOC
  • 34,367 POSTS
The clue is the rocking engine. That's controlled by the mounts. The only other factor is if idle speed is too high.
The torque converter clutch begins to lock up around 35 - 40 mph, when in the highest gears, and the engine is warmed up. Nothing related to it is engaged when the car is standing still. GM did have a big problem with that in the '80s. They wouldn't unlock as the car slowed, and it caused the engine to stall. Once stalled, it would release and allow the engine to be restarted. A lot of people "solved" that by unplugging the electrical connector for that solenoid, but that reduced fuel mileage.
Dec 20, 2017 at 11:21 AM
