Changed CV axle, seal, hub bearing, motor mount, and still have transmission fluid leak.
Friday, February 9th, 2018 AT 9:13 AM
MECHANIC
Where does the leak appear to be coming from?
Friday, February 9th, 2018 AT 9:58 AM
KEVIN ROSENBUM
MEMBER
CV axle into transmission passenger side.
Saturday, February 10th, 2018 AT 6:55 PM
MECHANIC
Okay, thanks.
There is a seal at the transmission for the axle. It is called a bulk head seal. You need to remove the axle again and use either a seal puller or a large screw driver with an angled end. Then be careful installing the new one as not to damage it. Then install the axle.
Sunday, February 11th, 2018 AT 12:31 AM
KEVIN ROSENBUM
MEMBER
So there is more than one seal you are telling me? Thanks.
Sunday, February 11th, 2018 AT 5:59 AM
MECHANIC
No, only one seal for that axle. There is another seal for the axle on the other side as well.
Sunday, February 11th, 2018 AT 2:13 PM
KEVIN ROSENBUM
MEMBER
Already changed seals.
Sunday, February 11th, 2018 AT 7:24 PM
MECHANIC
If they are still leaking, then there is another issue inside the transmission is a bushing that supports the axle shaft, if it is worn, there will be play in the shaft and that will cause the seal to leak.
