Transmission starts slipping after driving a couple of miles
2001 DODGE TRUCK
99,000 MILES • V8 • 4WD • AUTOMATIC
ROBERT HAND
It pulls and shifts good for about two miles then it starts slipping like it is in neutral and not sleep. it just does not pull. you let it set five to ten minutes start it up and it goes again for about two miles. it is like it is shifting into neutral.
Dec 25, 2016 at 6:48 PM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
With no other clues or test results to analyze, the most likely suspect is the fluid level is low due to a leak.
Dec 26, 2016 at 9:57 AM
