engine stalls
ERIN23
Just after starting the engine often the car will stall. When I am stopped at traffic lights, as a go to accelerate the car stalls. If I put the throttle to the floor, there is no acceleration and there is a weird noise as though the car doesn't know what gear to go in. Recently as I have been going to accelerate after stopping the traction control light flashes and I don't seem to have traction or power (it was raining)
I bought it off a mechanic who fixed the blown head gasket, replaced the cam sensor, fuel filter, oil, oil filter, spark plugs and leads.
I have recently replaced the air filter and the tires have plenty of tread. Help please.
Nov 9, 2013 at 3:47 PM
  • 55,782 POSTS
It sounds like you have a vacuum leak somewhere by the engine or the intake manifold is leaking, here is a guide that will show you how to find it.
You should also run the codes to see what come up
Cheers, Ken
May 30, 2017 at 5:45 AM
DALVISV
Engine Performance problem
1998 Holden Vectra 4 cyl Two Wheel Drive Manual 196543 miles
hi
I have 1998 holden vectra and i have severe engine stalling problem as soon as i deacclerate when this happens engine light comes on also some time TCS light comes on the the vehicle loose pick up and does not acclerate.I tried toc check the problem myself and i found some thing unusual when i trun on the ignition and leave it on for some time without engine running the TCS light glows and at the same time i can hear some kind of noise in the hood near inlet manifold and fuel injection rail as if some kind of kneumatic cylinder is actuating.Can u please tell me whats the problem.Thank you.
May 30, 2017 at 6:04 AM (Merged)
  • 31,937 POSTS
i there,
You will have to get a diagnostic code scan done to read any unresolved fault codes, i will need any codes to help work out what is going on, the noise may well be the idle control motor cycling through its range.
mark (mhpautos)
ANONYMOUS
  • 0 POST
It will run untill it gets hot then just dies it dosent seam to be a fuel problem though then if you crank the moter it somtimes backfires in the manifold.
  • 31,937 POSTS
Possibly a cam angle sensor as they are very problematic on these cars, get a scan for any fault codes first, start here.
May 30, 2017 at 6:05 AM (Merged)
