While driving traction control light came on, stutters over forty mph
2011 NISSAN ROGUE
14,196,100 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
HOPEOWSLEY
Traction control lights came on. No reason for it to just come on. The car will not go over forty without stuttering.
Nov 27, 2018 at 8:08 AM
  • 110,240 POSTS
It sounds like the traction control system is limiting engine power to prevent slipping or a spinning wheel, even though that is not happening. This could be the result of a bad wheel speed sensor.
What you need to do is have the computer scanned to determine what diagnostic trouble codes are stored in the computer. Once you get the code, let me know what it is. That will point us in the right direction for repair.
Here is a quick video showing how to use a scanner:
https://youtu.be/YV3TRZwer8k
I realize most people do not own a scanner. If that is the case, most parts stores will do it for free.
If you can, have that checked and let me know the results.
Nov 27, 2018 at 1:05 PM
