TPMS Light on and flashing
64,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
SILLYBOY
  • 18 POSTS
Hello, My TPMS light is constantly on, and sometimes flashing. The tires are at the right preasure.
No work has been done with the tires. The light just came on a couple weeks ago and stays on. It used to work fine.
The weather here is sixty five degrees in the day, and has been mild all week.
Is there a reset button on my Forenza for this annoyance?
Thank You
Feb 23, 2017 at 6:52 AM
STEVE W.
  • 15,410 POSTS
Light on and flashing when the pressures match the door sticker means you have at least one sensor that is not transmitting. Could be a any reason for that. Most common is the battery died in it (not replaceable).
Takes a TPMS tool to read them and find the dead one. Then you replace it and do a relearn and the light goes off until the next one fails or you have a low tire, whichever comes first.
Feb 23, 2017 at 7:07 PM
SILLYBOY
  • 18 POSTS
Thank you for the quick reply.
Feb 23, 2017 at 7:34 PM
STEVE W.
  • 15,410 POSTS
No problem. You can probably get that work done at a tire shop if you wish. With TPMS a required item on vehicles these days most places have tools.
Feb 23, 2017 at 8:59 PM
