94 tercel die when hot
1994 TOYOTA TERCEL
ALANCYLU
hi,
my 94 tercel, 210K, working fine when it's cold,
when it's hot, when you press gas a little, it's idle rough and die, especially when the heat fan is spinning if you press gas a little it will idle rough and die, when i try to restart it, it will blow black smoke but won't start. After i let it cool down about 30 mins to one hour, it can start again.
Please help me, i am really scare to stop in front of traffic light, because it could die any second if i press gas
Any response will great appreciate.
Aug 25, 2007 at 5:44 PM
[quote:7bc3389a92="alancylu"]hi,
Any response will great appreciate.[/quote:7bc3389a92]
When was the last major tune-up?
Aug 25, 2007 at 8:07 PM
ALANCYLU
Thanks for quick response,
Oil, oil filter, air filter changed , replaced spark plugs, spark plug cables, distributor cab, distributor replaced and timing adjusted one month ago. also use carb cleaner to clean TP at the same time, but still no luck,
BTW, it 's a 4 speed auto,please help,
Appreciate your great help.
Aug 26, 2007 at 3:49 AM
[quote:6df3023946="alancylu"]Hi,
Appreciate your great help.[/quote:6df3023946]
Find the PCV and EGR valves remove it and clean it up good-make sure both has vacuum and works. BTW also the IACV-then comeback with your findings
Before I put this Tercel on the operating table for Biopsy to get to the problem
Aug 26, 2007 at 10:40 AM
ALANCYLU
[quote:9df706235b="rasmataz"][quote:9df706235b="alancylu"]Hi,
Appreciate your great help.[/quote:9df706235b]
Before I put this Tercel on the operating table for Biopsy to get to the problem[/quote:9df706235b]
mine is Canadian model, EFI engine, i really can not find EGR and iacv valve, but i checked pcv valve and it has vacuum.
Please help me,
thanks a lot
Aug 27, 2007 at 3:38 PM
