1994 Toyota Tercel
BIGMUNN
  • 1994 TOYOTA TERCEL
Electrical problem
1994 Toyota Tercel 4 cyl Front Wheel Drive Manual
WHAT WOULD CAUSE THE CAR TO SHOW POWER BUT WHEN YOU TURN THE KEY TO START THE CAR, IT CLICKS AND SHOWS NO POWER. WHEN YOU MESS WITH TH BATTERY CABLES IT SHOWS POWER AGAIN.
Monday, December 1st, 2008 AT 8:28 PM
Clean the battery terminals and clamps and make sure its properly tightened then get back
Monday, December 1st, 2008 AT 8:45 PM
BIGMUNN
Have done that and still the same result. Also the car shows more power when touched by metal object.
Monday, December 1st, 2008 AT 8:52 PM
Get the battery load tested and comeback with the results. If its good start troubleshooting the ignition switch
Monday, December 1st, 2008 AT 11:14 PM
