1992 Toyota Tercel engine losing power and missing
DGAWRYCH
  • 1992 TOYOTA TERCEL
  • 4 CYL
  • FWD
  • MANUAL
  • 168,000 MILES
All of a sudden my engine started running rough, losing power, and missing. Both at idle and when I accelerate. What should I start to check?
Thursday, May 20th, 2010 AT 6:07 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Thursday, May 20th, 2010 AT 6:52 PM
WILROSE3
Have you found out what the problem is? I have the exact same problem right after I got my tune-up in April 2010.
Rosie
Friday, June 18th, 2010 AT 2:08 PM
