Hi baxtersmurf18, welcome to 2carpros and TY for the donation
No crank at all/nothing/nada:
Could be a blown fusible link, the starter, starter interlock relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Try shorting out the starter and see if it engages the engine
SPONSORED LINKS
Monday, June 7th, 2010 AT 12:26 PM
