1996 Toyota T-100 4WD
1996 TOYOTA T-100
15,000 MILES • 6 CYL • 4WD • AUTOMATIC
SNOWSKI11
My four wheel drive will not engauge. Will shift and front driveshatf turns but does not enggauge wheels. The dash Light does not come on and it has automatic locking hubs. Engine speed does also change in 4L. any input would be helpful thanks.
Dec 21, 2008 at 2:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
First you should check all fuses to ensure they are not blown. Next, check vacuum hoses to the hubs. If they are cracked or loose then they will not allow the 4x4 to engage. If these are all good, it may be a faulty solenoid.
Dec 21, 2008 at 10:54 AM
