1993 Toyota T-100 fuel problem
1993 TOYOTA T-100
270,000 MILES • 6 CYL • 4WD • MANUAL
NORTHTONY
  • 7 POSTS
i get in my truck cold and it starts up fine but when it gets to opperating temp and i turn it off and let it sit for five to ten min it will not start without starter fluid .i think im loosing residuel fuel pressure and the fuel is boiling in the lines . i replaced the fuel pump and had no problems for a short time but nor is worse than ever . i also changed the regulator with no change in performance.
Sep 25, 2010 at 10:13 AM
Do this block open the vane flap in the airflow meter and attempt to start-let me know
Sep 25, 2010 at 10:30 AM
NORTHTONY
  • 7 POSTS
i pushed the door open when the engine was cold and it started and now i cant get it to act up , it always has this problem untill i find someone to help, could that have fixed my problem and if it acts up again can i do your test and e mail u back on this site ? could my air vane be getting stuck and need to be replaced ? i dont like to throw parts at things so is there a test i could do to confirm that this was the problem ?
Sep 25, 2010 at 1:00 PM
NORTHTONY
  • 7 POSTS
i got it to act up again held the door open and no change in starting performance please help i have been fighting this for months and spent a ton of money on starter fluid and fuel pump and fuel regulator .
Sep 25, 2010 at 1:22 PM
Double check the circuit opening relay-the air flow meter grounds the COR coil side thru Fc circuit in order to power up the fuel pump.
Sep 25, 2010 at 3:42 PM
NORTHTONY
  • 7 POSTS
Pump has power and runs has 40 lbs but fuel line is full of air causing me to believe that the heat from the engin is boiling the fuel in the rail because of the loss of risidual pressure after it sits for about fifteen min that also would explain whay the starter fluud will let the truck start and run . i drive this thing all day and it runs great but if i turn it off it will not start for at least an hour unless i give it starterfluid so could a bad injector be causing it to leak down enough to cause that problem ?
Sep 26, 2010 at 5:43 PM
NORTHTONY
  • 7 POSTS
i couldnt get the truck to strart again and i held the air door open and had a friend start the truck and it worked sorry about the mis information . what should i do now that we know that holding that door open will make it strart and run?
Sep 27, 2010 at 10:16 AM
Replace the airflow meter
Sep 27, 2010 at 11:06 AM
NORTHTONY
  • 7 POSTS
i thinh that this is an accurate answer to my problem thatnk you for the help
Sep 27, 2010 at 11:56 AM
