1983 Toyota Supra Engine dies when gas pedal is depressed
246,000 MILES • 6 CYL • 2WD • MANUAL
1983TOYOTASUPRA
My 1983 supra (2.8 L inline 6) would die if the gas pedal is quickly depressed. Once the engine stops, it cannot be started again until some later time like the next day.
At first, I thought the engine is not getting enough fuel because dirty fuel filter. I replaced the fuel filter and that did not solve the problem. Next, I changed the fuel pump (brand new) but the same problem still exists.
After the engine stalled, I try to restart but without success. Next, I removed the spark plug and noticed that it is wet with gasoline. It looks like the fuel injector spays too much fuel onto the spark plug. I also checked to see if the spark plug is putting out the spark. The cap and rotor were damage with burn mark. I have replaced the cap, rotor and spark plugs. The problem is still there.
Next, I want to check if the air flow meter is working properly. What is the best way to test the AFM (vane type)?
Feb 5, 2008 at 4:47 AM
  • 75,988 POSTS
AFM bench test it -follow the repair manual- also check the fuel pressure-could be a problem with excessive pressure defective fuel pressure regulator/clogged return line-fuel pressure regulator ruptured
BTW did you check for spark when you replaced the plug/rotor/cap.
Feb 25, 2008 at 5:06 AM
