Clunking noise when shifting/or turning
2013 TOYOTA SIENNA
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICROMINT
There is this odd clunk from the front of the car. It usually happens under one of the following conditions:
1) After start up, I will turn the wheel slightly left onto the road. Upon proceeding there is this slight clink/clunk.
2) When I reverse into a parking space there is this clink/clunk again.
3) When going over a slight bump and turning the steering wheel, I get that clink/clunk again.
I have taken it to a repair shop and they ruled out tires, alignment, tie rod, transmission. So I am at a loss on what it could be. Boots and joints look good. There is a slight click feeling when it happens.
Help please!
Feb 18, 2018 at 2:59 AM
Good afternoon.
The first thing I would do is have all the motor mounts checked. This is a very common issue for this exact problem.
Feb 18, 2018 at 3:33 AM
MICROMINT
I will check and get back to you.
Feb 19, 2018 at 7:40 AM
Let us know what they find.
Feb 19, 2018 at 7:48 AM
