2003 Toyota Sienna
2003 TOYOTA SIENNA
JVIL
Brakes problem
2003 Toyota Sienna 6 cyl Two Wheel Drive Automatic
i just had my brakes (front and rear) replaced less than 2mos. ago. Now I hear my rear brakes whistling when stopping. What seems to be the problem? Does it need to be replaced again?
Oct 8, 2009 at 7:22 AM
DOCFIXIT
  • 18,828 POSTS
Most likely biuld up of brake dust.Do you know if rotor where turned? Noise when not braking or braking?
Oct 8, 2009 at 7:36 AM
JVIL
THANKS to DOCFIXIT.
Yes, they turned the rotors. I hear the noise when braking only. The moment I step on the brakes gently the whistling noise starts. What should I do next? Do I need to replace them or just clean it?
Oct 9, 2009 at 5:45 AM
DOCFIXIT
  • 18,828 POSTS
Try cleaning get some aerisol brake cleaner see if that helps.
Oct 9, 2009 at 5:49 AM
