2002 Toyota Rav4 Diagnostic Code Light
2002 TOYOTA RAV4
102,367 MILES • 4 CYL • 2WD • AUTOMATIC
3539JOSEPH
I received a light on the dashboard indicating a lean fuel mixture.
While checking the engine I noticed a hissing sound from the I think the egr sensor. One 1/4 inch vacummn hose on the bottom one 1/4 inch vacumn hose on the side and two 1/8 vacummn hoses on the sensor.
I taped the valve tight with electrical tape. Could this be the source of the problem???
thanks
Jun 28, 2009 at 7:33 AM
LEGITIMATE007
  • 5,121 POSTS
yes mostlikely it was, sounds like you had a vacuum leak which will cause a lean mixture check engine light , excellent observation, I would just get it done properly when I had the chance, scan it again and clear the code, awesome
Jun 28, 2009 at 7:35 AM
