2007 Toyota Prius dripping
SUNSWIMER02
Air Conditioning problem
2007 Toyota Prius Two Wheel Drive Automatic 45000 miles
I am not sure that it IS the A/C, that's what one of my friends said it might be...but this is the problem:
on the front passenger's seat some hot water drips down the inside of the car and pools on the floor boards, and I've noticed some cold water dripping on the driver's side now too but not as much and it doesnt pool.
Is it a hose that leaks? Is there a way to fix it? Is it an expensive fix?
Jun 11, 2010 at 1:24 PM
  • 31,937 POSTS
Hi there,
There are two things that you need to check here, first have the cooling system pressure tested for a leak in the heater core, secondly, have the A/C drain tube check for a blockage, start here.
mark (mhpautos)
Jun 11, 2010 at 4:00 PM
