1995 Toyota Previa
1995 TOYOTA PREVIA
NANCY VERVER
Interior problem
1995 Toyota Previa 4 cyl Two Wheel Drive 160 miles
how i remove or take off a broken key from the ignition
Dec 13, 2008 at 3:13 PM
  • 110,194 POSTS
If you can't access it, you will most likely need to remove the tumbler assembly. To do so, the steering wheel needs removed and part of the steering column. If you have an air bag, I would recommend having someone do it that has experience because it can deploy when working on it.
Sep 1, 2009 at 8:21 AM
