1993 Toyota Previa replacing rear brake light
1993 TOYOTA PREVIA
10,200 MILES • 4 CYL • 2WD • AUTOMATIC
LHERMAN
How do I remove the outer light covering so I can replace the rear brake light?
Jul 25, 2009 at 3:35 PM
Side brake lights -open the rear latch there's 2 philip head screws that's holding the brake light housing in place that you have to gently pry it-for the latch rear brakes-you need to remove the latch panel to get at it and also for the top center light.
Jul 25, 2009 at 4:59 PM
